I want to build
anthonyh
Re: I want to build
Post by anthonyh »
Nick wrote:Good luck, Anthony. I sure wish i had all your resources when I started!
John, how's that Rotec working out? There seems to be an element who believe Rotec engines are unreliable and that Rotec service is terrible. Can you comment? I'd love to have an R3600 on my Classic, but the rumors have me wondering. Would love to hear a real experience.
R28R36,
Your opinions are appreciated but in my opinion Nick was just asking John(who is flying with a Rotec) his experiences and expressed his concerns over what he had read at other forums/postings. Anyone who has been researching about getting an engine has seen all the postings good and bad( I have read them all) I believe Nick was just trying to get clarification from a trusted unbias source(John). I see nothing wrong with the post from Nick.
AS I stated earlier if my wife has her way I will be buying a Rotec 3600 for my Hatz. I would be happy with that engine and have no fears of flying with one. We shall see once I get closer to framing up the plane which way I go.
Now off to the fun part of building jigs!!
Anthony
hatzadmin
Site Admin
Re: I want to build
Post by hatzadmin »
Hello Jim,
My apologies for declaring you an owner.. that was a mistake on my part.
We certainly welcome your input and that of your sons if they so desire. As with many others I have read any feedback I could find (good or bad) about Rotec and what few negative things I could find all seemed to be tied to the people behind the website you listed previously... which, as you pointed out, has been discredited. I have yet to find any credible negative feedback about Rotec and have long since given up looking for any. There are certainly enough engines out there for the product to speak for itself.
As for Nick's post, I interpreted it to be Nick (perhaps stumbling across said discredited website?) and looking to hear real, honest, feedback from real customers.
So, I hope (think) we are past the miscommunications. Glad to have you among us Jim.
I'm looking forward to the day when an R3600 is hanging on my Hatz. 8-)
R28R36
Re: I want to build
Post by R28R36 »
Hi Doug and Anthony.
Thanks for your support and smoothing things over.
Just to ease my mind it might help if Nick and Anthony pointed me to references about Rotec's terrible service and the Rotec radial’s unreliability? After all these are harsh criticisms and it would be nice to correct such rumours or posts, or at least provide a reply to their criticisms. If Nick or Anthony feel uncomfortable using the forum they could email the info to me.
Jim
danielfindling
Re: I want to build
Post by danielfindling »
Anthony,
We have something in common, I am also starting my Hatz after purchasing plans in October or November and I have also ordered my wood (from Wicks). I built my rib Jig for 3/4 ply and also built a steaming steaming rig to steam the stringers.
For practice, I bought some cheap hardware store 1/4 ply and made some nose ribs on the router table from a wood master. After making several pieces I built a new master template out of 1/4 plexiglass and drilled three holes for brad nails to secure the wood. I also took a 4x6 and cut the airfoil shape on the band saw and steamed a few practice pieces of 1/4 inch hardware store wood. Everything seems to be very similar to balsa on plans construction (from my RC days).
Looking forward to sharing your struggles with this building process.
Daniel
As an aside, I had a shrinkage issue with my full size rib template from Makelen. Double check the dimension between the spars before building your Jig. (25", if my memory is correct). Doug was kind enough to share his CAD drawings from which I printed a new full size template (and also learned that the rollers on most printers will distort the drawing - so be careful with copies. - I found a guy with a plotter that avoided this printing issue.
anthonyh
Re: I want to build
Post by anthonyh »
Hi Daniel,
I also found an issue with the plan being off slightly. I cut the plan and corrected the 25" spar center dimension, it was only off by approx 1/64". I cut a piece of acrylic to the spar dimension and attached that to the Jig. The test rib came out great. I am waiting for a buddy to make his mind up on ordering a set of Hatz plans and building along with me. We will double the material orders and split the shipping cost. If he doesn't make his mind up soon I will place my order. I am limited at what I can do until I get my garage built this spring.
Jim,
I do not know where I ran into the particular post as I was all over the net while researching engine choices. I believe most of it was related to the links that you had already posted and I did not see anything that made me say no I do not want one of these engines.
Later!!
Anthony
