Stringers
Stringers
I was looking around for stringer material. The plans specify mahogany. A/S doesn't carry mahogany that I can find. They do have spruce T-Stringers. I haven't looked for a local source of mahogany. If I do find some, it'll probably be door frame material and I'll have to cut and splice it. I was thinking of using Sitka Spruce.
Any comments on using something other than mahogany?
I did read the posts on here about methods to keep the stringers from warping.
ssearle
Re: Stringers
Post by ssearle »
Hi Murry
I used locally supplied cherry but it is heavy. On my super cub that I rebuilt last year the original stringers were sitka, much lighter and easier to work with and scarf. I would go this way because they hold the fabric shape just as well.
Re: Stringers
I used D-spruce from the local lumber yard. Mine are not T-stringers but strait with rounded edges where they contact the fabric.
painless
Re: Stringers
Post by painless »
I bought 1x4 mahogany planks from the aviation isle at menards. Ripped them to size, rounded edges.
Jeff Orear
Hatz Classic #138
Peshtigo,WI
Re: Stringers
Thanks guys. The spruce is lighter than mahogany so that is a plus. I read that mahogany is resistant to warping. Probably why they use it for doors - and stringers. I do have the top 3/4" of my spars that I could use to make some T stringers. Just rip them down the middle and glue them into a T. I was thinking T stringers for strength both ways like an I beam. Probably earier to add more formers to keep the stringers straight.
I know they have quarter cut Sitka spruce locally. A 14' 1x6 would be nice. No splicing.
Re: Stringers
I ended up using the leftover tops of my spars for stringers for my Turtledeck that I made of wood. I bought a 14' 1x6 Sitha Spruce board locally for my side stringers. It's slightly less $ than capstrip from A/S and I don't have to have them shipped or splice them.
Full story here: http://myhatz.blogspot.com/2020/06/2020 ... -deck.html
