Ground Transportation
How much time and effort is required to remove/install the wings to trailer transport a Hatz Classic? Or alternatively, is it better to plan on not removing the wings and instead plan to accomodate the Hatz in a way that keeps the wings on except in the rarest of occasions?
Re: Ground Transportation
Check out this earlier thread:
viewtopic.php?f=8&t=369&p=2030&hilit=wing+removal#p2030
If that doesn't work, do a search for "wing removal" and it should lead you there.
Good luck,
Jeff
Good luck,
Jeff
