Wing Javelin
Posted: Sat Dec 22, 2012 1:12 pm
by mmcgrew
I have seen some finished planes without the wood "Javelins" (sp)
What are some thoughts on with and without?
TKS
N9648B
Re: Wing Javelin
Posted: Sat Dec 22, 2012 6:35 pm
by hatz215
I would definitely want them on the CB-1 because of the rear wires being close, and they just keep the wires 'quieter'. I used 3/4 dowels attached with rib stitch chord wrapping and spar varnish brushed on the chord which prevents unraveling.
I did a Waco RNF where I cut out two notched areas and made a 'plug' matching the cut out (with wire shaped recesses). I then attached the flush fitting plug with brass machine screws and nuts. I just like the old fashion look of the chord on my airplane.
Re: Wing Javelin
Posted: Mon Jan 28, 2013 3:08 am
by mark
what is the proper way to tension up the wires is it possible to use a tensiometer
Re: Wing Javelin
Posted: Mon Jan 28, 2013 1:51 pm
by hatz215
Here is a previous discussion from the archive.
http://www.hatzbiplane.com/dcforum/DCForumID1/477.html
Re: Wing Javelin
Posted: Mon Jan 28, 2013 9:28 pm
by mark
thanks alot that sounds like a good plan i have a regular cable tensiometer but did not know if it would work on a solid wire
