Page 2 of 2
Re: New Fuel Tank
Posted: Tue Jun 04, 2013 7:48 am
by alvinsager
Hi Scott,
Good news on the tank. I made a similar style tank for my CB-1, but thought I could be smarter by using .062" aluminum. It may have come out well if I were better at welding aluminum and/or my welder was more suited to the task. Bottom line was a very distorted top. I cut it off and riveted a flange all around the tank edge and riveted a new top on with closed end countersunk pulled rivets and pro-seal. I don't think is was worth the weight saving!
Re: New Fuel Tank
Posted: Tue Jun 04, 2013 8:47 am
I plan on installing steps on the landing gear and a retractable/sliding step higher up on the firewall similar to the Waco. After doing that I'll see how the reach looks and figure out where I want the fuel filler. My biggest concern is being able to fuel the plane anywhere I go without having to rely on a ladder. I know you can make it work from the cockpit, but that really isn't my preferred choice.
If you take a look at this video from Rare Aircraft you can see how the step works. He explains the step at 7:10 on the video.
http://www.youtube.com/watch?v=h0VyCXceG6w
Here's a couple pics from an RNF to see how it is attached.
Re: New Fuel Tank
Posted: Tue Jun 04, 2013 3:55 pm
Here are some photos of the removable step. The Waco RNF step design would also be good.
John Hanson HC-012
Re: New Fuel Tank
Posted: Tue Jun 04, 2013 4:01 pm
Our fuel tank holds 22 gallons and is made to the drawings.
John Hanson HC-012
Re: New Fuel Tank
Posted: Sat Jul 13, 2013 10:33 am
My Lauzon frame includes a step at the top of the front landing gear leg, about 4 or 5" from the top. I'm only 5'8" and my step puts me high enough to refuel, but not high enough to actually see into the tank. My fuel cap is offset to the right about 11" from center. So, anyone taller than me wouldn't have a problem refueling with the step welded to the gear leg. The only problem would be if I had wheel pants, it would be a long first step up not being able to step up on the tire first.
Re: New Fuel Tank
Posted: Mon Nov 04, 2013 1:39 pm
I have another tip to pass on for fuel tanks. I drilled a 3/16 inch hole in the bottom of the center section rear corners just in case a leak developed in the tank.
It would be nice to know there is a leak or seepage right away rather than have the fuel fill up the center section before you notice it.
John Hanson HC-012
Re: New Fuel Tank
Posted: Mon Nov 04, 2013 1:46 pm
Smart!!
jwhanson wrote:I have another tip to pass on for fuel tanks. I drilled a 3/16 inch hole in the bottom of the center section rear corners just in case a leak developed in the tank.
John Hanson HC-012
