Tie downs
arizonarotors
Tie downs
Post by arizonarotors »
I purchased Gary Root's Hatz Classic. I have a few hours on it now and it is a delight to fly. Gary tells me that when he built the aircraft they put in the tie down fittings but inadvertantly covered them during the covering process.
Can anyone tell me where they are on the Hatz Classic?
The only page of the plans I don't have is the bottom wing and I suspect that's where I'll find the info.
Thanks in advance for any help.
Jim
Re: Tie downs
Jim,
If built per plans, the tie down is located on the forward side of the front spar where the interplane struts attach.
The bottom wing plans don't really show the location.
Here's a shot of John Hanson's Hatz. You can see the tie down ring below the struts.
Re: Tie downs
The tie down hole location should be 2.900 inches outboard of the front interplane strut bolt hole and about 3/8 inch ahead of the front strut fitting plate. Drill a few 1/16 or smaller holes and feel for it. It should be 1/4-28 thread.
arizonarotors
Re: Tie downs
Thanks Guys, I'll look for them where you indicate.
Jim
